Plywood v chipboard for upper floors
Mr Punter
The engineer has specified 18mm ply for upper floors for this brick / block building.  I asked to change for 22mm Egger Protect chipboard.  They came back saying ply was needed for the overall stability strategy.
I like the Egger stuff because it stays in decent shape after exposure to the elements and it is a fair bit cheaper.
Are they correct or should I go back to them again?
Ply exposed to the elements wouldn’t last long 18 mil would require 400 centres 22 cabba or similar is the flooring of choice on most I boarded ours then sheeted it with plastic It was left exposed for six weeks without any adverse effect
9 minutes ago, markc said:
Im assuming the ply is specified for bracing. Ply is good in tension and compression, chipboard is only good in compression
OK I suppose they may need the tension property.  I am not sure why though.  We always have chipboard in timber frame stuff.  Does brick and block need something more special?
Generally no, brick and block is usually pretty stable. Maybe the overall design or lack on internal walls etc. making the Arch or Eng err on the safe sade
Edited by markc
side
It’s probably worth  counter battening the underside for plaster boarding This will also stop any twisting and will help stop floorboard creek later
No enough space.  They are nogged and will have resilient bar under.
