Pocster Posted April 3, 2021 Author Posted April 3, 2021 19 minutes ago, joe90 said: If you have the stuff then use it, why not do a trial area ? Do you have to fix the plastic feet so they don’t “walk”? No the feet are meant to just sit there . The weight of blocks holds them in place . One problem might be the amount of feet I need and hence cost ....
Mr Punter Posted April 3, 2021 Posted April 3, 2021 If you lay them offset you will need shedloads of feet. Even if you just have them stack bond you will need a foot for each block plus a load for the perimeter. I think you have already sussed that you will need to cut them as they will clash.
joe90 Posted April 3, 2021 Posted April 3, 2021 1 hour ago, pocster said: One problem might be the amount of feet I need and hence cost .... I thought you said you had them?, not enough? 1
Pocster Posted April 3, 2021 Author Posted April 3, 2021 1 minute ago, joe90 said: I thought you said you had them?, not enough? Yeah I’ve got 50 . But looking at this I might need 100’s !!
joe90 Posted April 3, 2021 Posted April 3, 2021 2 minutes ago, pocster said: . But looking at this I might need 100’s !! Cost/work benefit, cost an additional feet verses shifting stone/dust and levelling and compacting ?. 1
Pocster Posted April 3, 2021 Author Posted April 3, 2021 18 minutes ago, joe90 said: Cost/work benefit, cost an additional feet verses shifting stone/dust and levelling and compacting ?. I know !! ?
