19 minutes ago, joe90 said:
If you have the stuff then use it, why not do a trial area ? Do you have to fix the plastic feet so they don’t “walk”?
No the feet are meant to just sit there . The weight of blocks holds them in place . One problem might be the amount of feet I need and hence cost ....
If you lay them offset you will need shedloads of feet.  Even if you just have them stack bond you will need a foot for each block plus a load for the perimeter.  I think you have already sussed that you will need to cut them as they will clash.
I thought you said you had them?, not enough?
Yeah I’ve got 50 . But looking at this I might need 100’s !!
Cost/work benefit, cost an additional feet verses shifting stone/dust and levelling and compacting ?.
I know !! ?
