SWMBO wants a tiled wall inside running the full height of the stair well .
About 3m wide and 6m high . So this runs from the dungeon up to the ceiling at ground floor .
I’ve got to build / board a wall to take the tiles . But what should I use ? . No need for protection from damp/water . SWMBO wants some small tiles ( so probably need a billion of them ) . Rather than tile adhesive could I stick them on with ct1 ? . But stick to what ? Osb ?
OSB will be perfect for this, i would use tile adhesive as its cheaper and easier to cover a large area.
I just thought it would be quicker with ct 1 . Blob on tile , stick - repeat x 1000000
Wasn’t sure if tile adhesive would take to osb ...
So this type of thing
https://www.crowntiles.co.uk/cubics-grey-porcelain-wall-tiles.html?gclid=CjwKCAjwu5CDBhB9EiwA0w6sLfBL8rzaqifupt5BRQ-Ngtt87d3vDtROzBLs8DZSC3Zz8cgSI1s0dxoCkoAQAvD_BwE
I presume I can place them tight to each so no grouting ! ?
Yes, no need to grout if decorative only
Don’t use CT1, just use solvent based no nails type adhesive at £1.50 a tube if you are doing it onto OSB.
Reason being it’s cheaper ? ( rather than an issue using ct1 )
And more suitable as you only need a construction adhesive here. No moisture or sealing, no real need for a hybrid polymer adhesive.
Why do you think you should need CT1..?
Because the answer to the meaning of life and the universe is ct1
Not what I would be using. You want something solvent based that goes off quick so it bonds and doesn’t come off. CT1 isn’t the answer there.
Ok ! Noted ! Ct1 not the bad boy here ?
42 tubes of it
  • Haha 1
