ash_scotland88 Posted March 25, 2021 Posted March 25, 2021 We have an attic with proper stairs, all original. The make-up is from appearance Lathe and plaster Joists Floor boards The actual walking floor is is quite high up from the lathe and plaster. I'd need to measure but I'd say a good 300-450mm. Around the attic one can access between the joists (flooring isn't to the edge) and (hoping) a line or two carefully removed from the centre of the toungue and grove boards to be returned. Is blown insulation an option here? Anything to be aware of? Anyone have handy links to read up on it?
the_r_sole Posted March 25, 2021 Posted March 25, 2021 are you trying to insulate the midfloor? What's the reasoning?
markc Posted March 25, 2021 Posted March 25, 2021 Insulating the attic floor wont do much unless you also insulate the entrance etc. but as above, why do you want to make a cold attic?
ash_scotland88 Posted March 25, 2021 Author Posted March 25, 2021 Currently it's just storage. I thought it makes more sense as any heat rising from the rooms below will be "trapped" by the insulation between their ceiling and the attic floor. Instead of having of to heat the room below and then the attic before finally being "trapped" by the installation of rafter insulation.
