Is there any reason as to why you can't lay porcelain slabs individually in an otherwise gravel path?
While I realise they need to bedded in cement we are being told they must butt against each other or they will break.
Thanks.
  On 18/03/2021 at 14:59, nod said:
No
It’s the opposite to what you have been told
5 mil to 25 joint is fine
Expand
So if we want them dotted randomly about a gravel path for example we just need a bed of cement underneath each individual slab?
I have done this with stone slabs on a bed of sharp sand / cement a bit wider than the slabs, haunched around.  If the porcelain is thick and non-slip I don't see a problem.
Expand
Yes
Porcelain is extremely durable
