Rufus77 Posted March 16, 2021 Posted March 16, 2021 Last year we noticed a growing damp patch on the inside of a gable end wall next to the chimney breast in an upstairs room. It eventually got so damp that part of the ceiling collapsed. We hired a roofer to fix the leak but despite having a new roof on half of the house and having the chimney repointed and reflashed, the internal wall and ceiling are still damp. We’ve had a dehumidifier on full every day but it just isn’t drying out. There is some cracking to the rendering on the external wall although it’s not exactly where the internal damp problem is. We’re also aware that we have a lack of ventilation in our loft space but could either of these things be causing such damage? I’ve attached some photos. Can anyone please advise what could be causing the problem and how we can fix it. Many thanks.
SteamyTea Posted March 16, 2021 Posted March 16, 2021 I had some cracked render, the water came in a good 2 metres from the damage. I also had the loft insulation move (as have half my neighbours) a few inches in a storm. Was enough to just cover over the soffit vents, then each time a hoolie came in, water got soaked up into it, then into the ceiling below. 1
markc Posted March 16, 2021 Posted March 16, 2021 Trying to look at the pics on a small screen so correct me if im wrong. Is there a gap under the flashing that will allow water under and onto/over the gable boards? ks like Whats stopping water being blown under the blue flashing? 1
tonyshouse Posted March 16, 2021 Posted March 16, 2021 Rotten mortar on the chimney sucks in water when it rains, this then percolates downwards through the walls and tries to get out inside and outside 1
Rufus77 Posted March 17, 2021 Author Posted March 17, 2021 On 16/03/2021 at 16:54, markc said: Trying to look at the pics on a small screen so correct me if im wrong. Is there a gap under the flashing that will allow water under and onto/over the gable boards? ks like Whats stopping water being blown under the blue flashing? Expand No there's no gap. I think it's just the photo.
Rufus77 Posted March 17, 2021 Author Posted March 17, 2021 We've had the chimney repointed. Would painting it with a breathable brick sealant be a good idea?
Rufus77 Posted March 18, 2021 Author Posted March 18, 2021 On 17/03/2021 at 18:50, tonyshouse said: No Expand Thanks. Do they not work then?
tonyshouse Posted March 18, 2021 Posted March 18, 2021 Might make it worse water running down can capillary into cracks and then find a downhill path onside the masonry effectively sucking water in, previously water was absorbed by the bricks a bit is then available to be drawn in.
