Hi everyone
Currently building our home in South Wales including a basement!
Using a bore hole for water, ground source heat pump for hot water.. and looking at solar tiles/insert options.  Always looking for inspiration along the way!
You can follow our journey on instagram:
https://www.instagram.com/our.dream.in.squares/
Looks an interesting project.
Any reason why ground source? It's a rare situation in which the higher costs of ground source relative to air source stack up.
Another basement built here, passive standard with timber frame on top.
Looks impressive - what energy performance standard are your aiming for?
Quite a bit of glazing so beware of overheating risk - have you done any modelling to determine heating /cooling requirements?
Agree with Jack - ground source is expensive so interested in why you chose that.
One of the founder members here @Jeremy Harris did a borehole and had a lot of challenges with but eventually succeeded. He's not an active poster anymore but there are lots of posts here relating to it.
Edited by Bitpipe
