Hi Group,
Me and my partner are currently working through our building warrant and SAP calcs stuff,
What would be a good u value or thickness of insulation for the ground floor with UFH? Would 150mm be a enough?
So far our builder has suggested i think
The external walls will be frametherm 32 150mm thick, horizontal FF ceiling 2layers totalling 400mm wool and sloping parts of ceiling will have PIR board (150mm) with 2nd board (20mm)over the face.
Its all about the sap guy but i want a good insulated house, just lookong for past experiences
Mike
This is relatively poor at probably not lower than U=0.25
If this DIY shed loftwool, thermal conductivity 0.044W/m2 .K then the U-value will be around 0.13
U--value around 0.20-0.22
With the floor area and external perimeter I can calculate a U-value
Ermmm i think its 19m length by 7.5m wide.
Floor area is about 230m2 or therby.
The architect reckons a B rated house but maybe not of really poor insulation.
If the ground floor is a 19 x 7.5 metre rectangle, 150mm of PIR or anything else of equivalent thermal resistance will give a Passivhaus level 0.11 U-value.
Personally I think you need another 100mm on the walls and 75mm on the sloping ceiling (same material) to get U values down to 0.12/0.14
Edited by A_L
minor typo
Yeah it is a rectangle, roughly  19m by 7.5m its 1.5 storey.
I will wait and see the SAP calcs and then ask what the price would be to upgrade the insulation.
So what is a good thickness level for roof, sloping ceiling, walls and floor? Or u value.
Thanks,
MIKE
