Baz zee Posted February 23, 2021 Share Posted February 23, 2021 Hi looking for some advice if anyone can help? Bear with me on this. We are currently planning to build an outbuilding in our back garden. The footprint is going to be 7.2m by 2.4m with a hight of 1.8m at the rear and 2.4m at the front. It is going to be situated approx 600-700mm off the property boundary to the rear and sides. The garden used to have a slight slope running from one of the back corners to the opposite front corner, which I have leveled off in to 2 sections. One been a section we plan to place the outbuilding on (level with the garden to the rear of the property) the other the rest of the garden (level with the house). With me leveling it, the drop off from one level to the other is appropriately 400-450mm. More on the building its self. So I plan on sectioning it into 3 sections at 2400mm by 2400mm the one to the right a small workshop/shed. The middle section an open fronted seated area with full width steps opening upto the rest of garden. The section to the right enclosed for the hot tub. All sections enclosed under one roof and cladded all round. A couple of questions.. 1) I was planning to deck the base of it throughout. But looking at regulations a decked area needs permission if its over 300mm from the ground. Will this fall under them regulations? 2) Are there any other regulations I should be aware of? Before I start fixing the base. 3) would I get away with using 100 x 47 c16 spaced at 400mm for the deck? With posts at 100x100 for the corners and 75x75 every 1800mm to support the roof? I'm sure I will have more questions, any questions please ask, thank you in advance. Link to comment Share on other sites More sharing options...
Baz zee Posted February 23, 2021 Author Share Posted February 23, 2021 Sorry just realised I have posted this in the introduction section if someone could move it to the relevant section. Thankyou. Link to comment Share on other sites More sharing options...
keith65 Posted February 23, 2021 Share Posted February 23, 2021 Yes you would need to look at fire regulations as you are close to the boundary Link to comment Share on other sites More sharing options...
Baz zee Posted February 23, 2021 Author Share Posted February 23, 2021 32 minutes ago, keith65 said: Yes you would need to look at fire regulations as you are close to the boundary Thanks Keith, I didn't think about fire regs. Link to comment Share on other sites More sharing options...
Conor Posted February 23, 2021 Share Posted February 23, 2021 If you're building within 1metre of a boundary the building must be made from "predominantly non combustible" materials. I.e. not timber. Link to comment Share on other sites More sharing options...
Baz zee Posted February 23, 2021 Author Share Posted February 23, 2021 (edited) 1 hour ago, Conor said: If you're building within 1metre of a boundary the building must be made from "predominantly non combustible" materials. I.e. not timber. What if I make the footprint under 15m2? Would that change that requirement? Also would it be classed as one building even though its in 3 sections? Edited February 23, 2021 by Baz zee Link to comment Share on other sites More sharing options...
Temp Posted February 24, 2021 Share Posted February 24, 2021 9 hours ago, Baz zee said: 1) I was planning to deck the base of it throughout. But looking at regulations a decked area needs permission if its over 300mm from the ground. Will this fall under them regulations? Heights are normally measured from the highest ground immediately adjacent to the building/deck. I found this appeal which covers decking on sloping ground.. https://www.merton.gov.uk/assets/Documents/22 St Georges Rd Appeal Decision May 19 Decking a d Fence and Extension.pdf What I don't know is if the government have changed the rules since or if they have gone to the high Court to get it overturned. Link to comment Share on other sites More sharing options...
Baz zee Posted February 24, 2021 Author Share Posted February 24, 2021 (edited) Thankyou temp. I feel a little more confident in building it now. I have redrawn the plans to reduce the foot print to 14.98m2 as its within 1m of the boundary, as it states any building with a footprint of 15-30m2 are subject to the fire regs. My neighbour to the side has something similar in their back garden, I will be having a chat with then today to see what or if permissions where needed. Edited February 24, 2021 by Baz zee Link to comment Share on other sites More sharing options...
