regaldridge Posted February 17, 2021 Posted February 17, 2021 Hi Folks, New member here ... Just completing the installation of an LG 7kw ASHP heat pump and looking for inspiration for making it work sweetly. We have a new house with top class insulation everywhere and double glazing plus solar panels and TESLA house battery plus Zappi EV charger and EDDI smart immersion, Ground floor is UFH and upstairs normal rads. We are both 72 and like "cold" houses (?) Getting ready to tune the heat pump once install completed .... any tips? LG ASHP documentation seems very thin on the ground, particularly regarding the controller and its thousands of seemingly contradictory options?
SteamyTea Posted February 17, 2021 Posted February 17, 2021 Two things, how much insulation do you have under the floor heating and do you have a buffer tank fitted?
ProDave Posted February 17, 2021 Posted February 17, 2021 No 1, before the installers leave, get them to show you: How to set the times that the heating and hot water are on and off How to set the hot water temperature How to set the heating water temperature How to set, turn on, off or adjust any anti legoinairs program be ready with a load of post it notes to mark the relavant sections in the user manual as they explain it to you. 1
SteamyTea Posted February 17, 2021 Posted February 17, 2021 7 minutes ago, ProDave said: anti legoinairs program Which may be called Disinfectant 1
