Jase Posted February 15, 2021 Posted February 15, 2021 Hi all hopefully some one can help? Doing my kitchen out all the plaster is off the walls .The internal wall were the radiator is going had the old pipes running down the the wall which looked naff.so my question is can I chase out some of the brick out to allow the 15mm copper to run internally behind green plaster board?.If so is it best to lag the pipe so to reduce possible condensation causing issues ? Many thanks in advance Jason.
PeterW Posted February 15, 2021 Posted February 15, 2021 Condensation won’t form but chasing them would be preferable. 1
Nickfromwales Posted February 15, 2021 Posted February 15, 2021 Chase them in, PVC tape the pipe, and then use expanding foam to fully encapsulate the pipe. If you don't then the heat from the pipes will be forever heating a cold wall. 1
Jase Posted February 15, 2021 Author Posted February 15, 2021 Thanks guys when you say pvc tape is that the same as electrical tape? Regards jason.
Nickfromwales Posted February 15, 2021 Posted February 15, 2021 23 minutes ago, Jase said: Thanks guys when you say pvc tape is that the same as electrical tape? Regards jason. yup
