Jeremy Posted February 14, 2021 Posted February 14, 2021 I've settled on a Telford unvented cylinder to replace a 30 year old (or more!) vented tank/cistern. After contacting Telford, I've learned that they don't do direct sales, so I'm wondering who folks on the forum have purchased theirs through. Pricing with online vendors for these seems quite idiosyncratic - e.g. I'm looking for a heat pump / solar tank, probably pre-plumbed, and these should be just a hundred or two pounds more than the basic uvc, but from some sellers they're £500-800 more. Any tips on how you purchased yours? I've already got a local G3 certified plumber/installer lined up to do the plumbing work and hand-off to heat-pump guys to finish the job. I just can't see any upside to paying the installer a 30%+ markup for a pre-plumbed cylinder...
Nickfromwales Posted February 14, 2021 Posted February 14, 2021 We did a Bh group / bulk purchase a while back with Trevor of Cylinders2go. Give him a call and mention the forum
PeterW Posted February 14, 2021 Posted February 14, 2021 (edited) Why do you think a pre plumbed cylinder should only be £1-200 more than a standard ..?? Most are fitted with a pair of branded valves, wiring centre, bypass valve and all done using 22mm copper. That’s around £150 of parts and they are around £300 more if you look around and that’s value for money, assuming everything is in the right place in terms of connections. In terms of purchase, most of us use Cylinders2Go and if you mention the forum, Trevor will sort what you need. The benefit of going with Telford is they will customize all the connections to where you want them - last one I had I needed everything in the 12-2pm and they did it no problem. Edited February 14, 2021 by PeterW Crossed with Nick on the supplier
Jeremy Posted February 14, 2021 Author Posted February 14, 2021 1 minute ago, PeterW said: Why do you think a pre plumbed cylinder should only be £1-200 more than a standard ..?? Most are fitted with a pair of branded valves, wiring centre, bypass valve and all done using 22mm copper. That’s around £150 of parts and they are around £300 more if you look around and that’s value for money, assuming everything is in the right place in terms of connections. In terms of purchase, most of us use Cylinders2Go and if you mention the forum, Trevor will sort what you need. The benefit of going with Telford is they will customize all the connections to where you want them - last one I had I needed everything in the 12-2pm and they did it no problem. Epic. Will check in with c2g tomorrow! Re: pre-plumbed, not surprising I'm off in my estimation - that was just based on a few comparisons across other vendors. But would you agree that it's probably easier and cheapter to get a pre-plumbed cylinder?
Nickfromwales Posted February 14, 2021 Posted February 14, 2021 Can be 6 and two 3’s tbh. Pre plumbed has a lot of gear in one tight footprint. Depends on fitter and where it’s being located / service access etc.
dpmiller Posted February 14, 2021 Posted February 14, 2021 there are other suppliers of very similar bespoke units that *will* deal direct, too.
Jeremy Posted February 15, 2021 Author Posted February 15, 2021 On 14/02/2021 at 17:18, dpmiller said: there are other suppliers of very similar bespoke units that *will* deal direct, too. anything you'd recommend specifically?
Nickfromwales Posted February 15, 2021 Posted February 15, 2021 Newark for one. Joule cylinders are made by Telford iirc.
PeterW Posted February 15, 2021 Posted February 15, 2021 Newark are very good but won’t sell direct on UVCs unless you have a G3 ticket
dpmiller Posted February 15, 2021 Posted February 15, 2021 I dealt with World Heat, very accommodating.
