Hi All,
Wasn't sure of the best forum for this question so apologies if I'm in the wrong one.
My build will be brick and block.
After plumbing and electrics 1st fix I plan to go over my build searching out and filling any gaps prior to the plasterer coming in.
What are the best products to use?
Similarly, after the plasterer and electric 2nd fix, I will be up in the loft going over things and checking the rest of the house around skirting areas etc
Any advice on this and best products? Tapes, silicon etc
Cheers
You can get an airtight foam in a can (Blue) Do around the joists any obvious holes Frames and external casings
If your loft is a cold loft Vented around the soffits
I would worry to much up there As it will be sealed from the rest of the house
If the plasterers do there job properly ie Acoustic seal the ceilings to the block work Solid dabs in ALL angles and skirting lines Solid around all sockets
You should be pretty airtight
Thank you for the replies.
Blowerproof looks a good product
Is this the airtight foam
https://www.insulationsuperstore.co.uk/product/soudal-soudafoam-window-and-door-airtight-flexible-pu-foam-box-of-12.html
Yes, my loft is a cold loft.  My concern is the light fittings.  I assume the plaster skim will seal the ceiling boards and I plan to keep a close eye on the plasterer to make sure they use a continuous bead to fix the boards.  Should they use a special product to 'acoustic seal' the ceilings?
You should include a vapour control layer under your ceiling, then a service batten then boards, don’t rely on boards and plaster to be air tight.
You can get lots of lights that will fit in this 25mm void so you don’t puncture the vcl.
