goatcarrot Posted January 26, 2021 Share Posted January 26, 2021 Tall and wide stone Dutch barn 12 x 7 m external foot print. Structure not great as never had flooring tied in. Thinking about putting an insulated foundation to build internal block walls off and maybe around the internal perimeter to form a super structure inside, insulated from the stone. any views on viability/expense or better ideas gratefully received. Link to comment Share on other sites More sharing options...
Iceverge Posted January 26, 2021 Share Posted January 26, 2021 More info needed about the current structure. What's it made from? How thick are the walls? Is it in good condition? Link to comment Share on other sites More sharing options...
goatcarrot Posted January 26, 2021 Author Share Posted January 26, 2021 It’s double skin random stone and lime about 18” thick. The gables are not too bad but the one side wall is bellied quite bad so would need tie-ing in somehow. Other side is two stone columns with open gaps in between hence dutch barn. needs strip footings then diaphragm walls building between the columns and other side wall to stiffen it up and build upper floors off. Link to comment Share on other sites More sharing options...
goatcarrot Posted January 26, 2021 Author Share Posted January 26, 2021 I’ve had a structural design done but that was before I thought about Passivhaus Link to comment Share on other sites More sharing options...
Iceverge Posted January 26, 2021 Share Posted January 26, 2021 The building sounds like it would need a lot of work to take to a habitable standards. Your remaining internal space would be small, especially if you use block inner leaf. Where do you sit with planning permission, conservation status etc? Pictures or drawings might help. Link to comment Share on other sites More sharing options...
goatcarrot Posted January 26, 2021 Author Share Posted January 26, 2021 No doubt it would need a lot of work. it’s tall so could accommodate 3 floors (I know fire regs more stringent) so wall thickness not really an issue. possible class Q but if not I don’t think planning would be too hard to get. thanks for your interest Link to comment Share on other sites More sharing options...
Iceverge Posted January 27, 2021 Share Posted January 27, 2021 Do you own the property or are you just feeling it out. Before going much further down the line I'd get the views of someone with the authority to analyse structure and see if its possible to salvage. Without knowing any more my gut is telling me that it's a non starter given the problems with the existing barn. Link to comment Share on other sites More sharing options...
goatcarrot Posted January 27, 2021 Author Share Posted January 27, 2021 Property already owned. as mentioned I’ve already had an SE draw up plans to salvage it with a view to convert down the line but that was before I realised it had potential for a PH retrofit/conversion. say the barn was already structurally sound, how would you go about converting such a building? Link to comment Share on other sites More sharing options...
HerbJ Posted January 27, 2021 Share Posted January 27, 2021 Try the Greenbuilding Store for information. They have a lot of case studies that may be useful. https://www.greenbuildingstore.co.uk/category/case-studies/ 1 Link to comment Share on other sites More sharing options...
goatcarrot Posted January 27, 2021 Author Share Posted January 27, 2021 Thanks for the link, some great ideas there Link to comment Share on other sites More sharing options...
