Hey,
is it possible to prevent Bricks with small spots of defacing from becoming worse?  They don't look bad enough to warrant replacing but they have either been damaged from construction or from Frost.
My feeling is it was damaged during pressure washing when it was built 6 years ago...it's little spots on numerous bricks with no sign of major water retention
The home we lived in previously was on a new build site and was plagued with this problem
Mostly exposed areas such as chimney stacks They replaced effected bricks and sprayed these areas which seemed to slow things down But eventually most stacks and effected  areas where replaced
The site was made up of three colours of brick All by the same manufacture Red Buff brown
Out of the 145 houses only the Buff was effected
Not sure why
