WWilts Posted January 22, 2021 Posted January 22, 2021 Structural design so far has been traditional inner block + full fill cavity + outer brick (cast stone for front elevation only) Came across thin joint blockwork + monocouche render. Very tempting. Plentiful supply if I understood right. Shorter time to watertight. Are there serious downsides to the blockwork & render option?
nod Posted January 22, 2021 Posted January 22, 2021 There’s not much between both Face brick and Labour more than block and block Though the added render will take you to a similar cost As you say Block and Block is quicker to watertight And a week of decent weather will see off most 200-300 m2 jobs Monocouche render is easy to apply and problem and maintenance free As a render contractor I would advise you to get an experienced company to do the render not just the guy who’s going to skim the internal walls and go and have a look at there previous work 1
MikeGrahamT21 Posted January 22, 2021 Posted January 22, 2021 Insulation choice gets squeezed with thin joints, but as you say full fill i'm guessing you are going for fibreglass/wool? If so this will be OK. If you are thinking full fill PIR, this is a no go, as the boards are designed for traditional mortar joints, not thin joint. 1
WWilts Posted January 22, 2021 Author Posted January 22, 2021 (edited) Thanks @nod 1 hour ago, MikeGrahamT21 said: If you are thinking full fill PIR, this is a no go, as the boards are designed for traditional mortar joints, not thin joint. Did not know this. Is wool the only remaining option? Earthwool DriTherm Cavity Slabs: that's in the design. Might it work with thin joint blockwork? Edited January 22, 2021 by WWilts
