bobh Posted January 19, 2021 Posted January 19, 2021 Our SW drainage requires a 0.4l/s flow restriction before the outfall. Now to my mind this is as simple as a capped pipe exiting a silt trap chamber with an appropriately sized hole drilled in it to give the required flow. Do we think this would be suitable or do I need to spend a few hundred pounds on a ready made product?
PeterW Posted January 19, 2021 Posted January 19, 2021 How big is the roof ..? And what will hold the attenuated water ..?
bobh Posted January 19, 2021 Author Posted January 19, 2021 The total roof cover is 136m² The system has been designed with 150mm pipe rather than 110 to include a 10 m filter trench as well
CivilEng2020 Posted January 22, 2021 Posted January 22, 2021 I don't think there is a flow control with such low flow rate, I think the minimum you can get out there is 0.7 l/s. Who requires the outfall to be 0.4 l/s if I may ask?
bobh Posted January 23, 2021 Author Posted January 23, 2021 14 hours ago, CivilEng2020 said: I don't think there is a flow control with such low flow rate, I think the minimum you can get out there is 0.7 l/s. Who requires the outfall to be 0.4 l/s if I may ask? Drainage layout was designed by our engineers along with the foundations. I've found a company that will supply a 0.4l/s restrictor which is essentially a silt trap with a cap on the exit pipe with an appropriately sized hole in it and then a filter fitted to it. I'm pretty sure I could make the same myself but don't know if building inspector would ok it. Scotland based if that makes a diffrrence
