I'm looking for some general information about lofts to help me with a project but I can't find much online and I can't even visit friends and family to have a look at theirs so I would be grateful if anyone with experience of lofts you could enlighten me on the questions below:
- Do most houses have a loft?
- Where is the loft hatch usually located? (landing or bedrooms?)
- Is there usually a lot of space around the loft hatch? (i.e. is it usually located far from walls and doors?)
- Are loft hatches usually the same shape and size?
- Does the hatch usually open inwards or outwards?
- What is the most common method of accessing a loft? (portable ladder or ladder attached to the hatch?)
- Is the floor inside the loft usually flat? (or are there different height beams etc?)
Any help answering these questions would be much appreciated!
Unless the roof is flat, there will be an area than needs to be servicable and that you can define as 'loft'
Landing, unless layout forces it to be in a bedroom (see below)
It depends on roof construction, but you want to place the hatch in, or close to, place where there is the most headroom - or at least enough to access the loft
No, but most are designed to fit between joists at 600mm centres, so about 550mm. Length varies and you can pick your own depending on type and space available
Upwards if the hatch is just a board in a frame, downwards if hinged. But not impossible to modify the first type to hinge upwards.
Don't know the statistics, it will depend on the use: for servicing only - use smaller hatch (easier to fit) and use a ladder when needed; for frequent access (storage, maintenance of devices etc) having build-in folding stairs makes more sense, but comes with size and price
Floor usually is flat, but you need to lay it first. For sure there are joists running parallel at regular (and standard: 400 or 600m centres) distance.
how much you paying for us doing your coursework for you!
