I'm trying to find information on sizing to and from an UFH manifold. Does any one know of a source please?
The run is approx. 12m and LoopCad says ~ 15l/min needed in total for the UFH loops.
Many thanks.
  • 2 weeks later...
@PeterW Hi Peter,
Heat source is an oil (system) boiler and I'm looking at whether/how to use a buffer as I'm concerned about the boiler cycling too much.
On the issue of buffers.................I'm actually just going through that now.
My current thinking is to use a 150/200l indirect tank to buffer (LoodCad suggests UFH is about 11kW, which correlates reasonably well with my heatloss calcs). It will only serve the UFH.
I'm getting a little lost on whether the tank needs to be vented or can be sealed.
The coil would be from the boiler but would the UFH side then be classified as unvented (due to tank size) and come under G3 if it was a sealed system?
I could alternatively fit a small F&E tank directly above the tank if needed
100 litre buffer will be fine - don’t bother with a coil, just make sure there is a mag filter on the way back to the boiler.
