Ferdinand Posted December 15, 2020 Posted December 15, 2020 This is a spin off from the other thread, thinking about window frames heating up and expanding. Does anyone have any observations about colours of modern windows in warmer countries - say Italy / France / Spain? That is perhaps where our climate is heading. To be fair, for some places that will mean "less cold". Ferdinand
MikeGrahamT21 Posted December 15, 2020 Posted December 15, 2020 My personal view is that the overall climate is less of a problem for window frame colour. Its more the direct heat of the sun which causes any warping/distortion etc. If the general climate is warmer, then this in theory should be less of an issue, but the sun will still heat the frames to a good 70-80C.
Ferdinand Posted December 15, 2020 Author Posted December 15, 2020 Agreed - the temperature the frame reaches. Inside my front rooms it happily runs up to nearly 40C currently sometimes, but the Oak colour UPVC frames take whatever their temperature reaches,
SteamyTea Posted December 15, 2020 Posted December 15, 2020 (edited) 5 hours ago, MikeGrahamT21 said: My personal view is that the overall climate is less of a problem for window frame colour. Its more the direct heat of the sun which causes any warping/distortion etc. If the general climate is warmer, then this in theory should be less of an issue, but the sun will still heat the frames to a good 70-80C. Yes. And the sun is not getting any hotter. You can work out the max temp from the power of the sun (no more than 1200W.m-2) and the SHC of the material the frame is made from (PVC 840 - 1170 J.kg-1.K-1, Timber between 1300 and 2500). Expansion of PVC is 50-6 m.m-1.K-1, timber 3-30 -6 m.m-1.K-1 Edited December 15, 2020 by SteamyTea
