Whats the adhesive to use?
I've googled it and looked but for god sake a simple question and I still can't find the answer
found it...what a faff
2. Application
2.1 Use on cement based substrates
Using a 5 – 8mm notched trowel, a continuous bed of ce- ment based single part flexible adhesive should be laid on the floor. The boards must be firmly bedded into the adhesive by gently pushing back and forth. The boards should be laid in a ‘brick bond’ pattern and checked for level with a spirit level.
I had cill height 40mm ish above porch slab and was slabbed up to cill for level access. Signed off, slabs ripped up, porch erected now just bringing the floor back up a bit and covering it nicely.
20 minutes ago, Oz07 said:
No probs
Ive also used it on timber floors to straighten up Then driven screws in the following morning Great product
Nice and light easy to cut
