AlanUK Posted November 30, 2020 Posted November 30, 2020 I notice the tongue isn't centrally placed on the board edge, but is slightly closer to one side. Does it matter which side is uppermost - the side nearest the tongue, or the one further away? Or is it a matter of just picking one and going for it?
markc Posted November 30, 2020 Posted November 30, 2020 (edited) tongue/groove position depends on the machine used to do it and whether the person setting the machine bothers to adjust it. often different thickness boards are run through at the same setting. as to which side - check whether one has a chamfer? then decide if you prefer the close butted look or v groove Edited November 30, 2020 by markc
AlanUK Posted November 30, 2020 Author Posted November 30, 2020 Ah, thanks. That suggests it doesn't much matter then. The boards don't have a chamfer, so both sides are the same. 1
Dee J Posted November 30, 2020 Posted November 30, 2020 The growth rings of timber tend to straighten with drying. And it tends to be preferable that floorboards dome up in the centre rather than cup with raised edges. Have a look at the end of the planks to see how that might work out.
