How smooth does sub floor need to be before insulation for UFH installed
readiescards
Do I need to be concerned about 3-5mm height difference between the blocks and beams in my sub floor?
The plan is for a DP membrane (not sure of thickness), 200mm of PIR foam, ufh in 50-60mm concrete screed, Luxury vinyl tiles.
Options I see are:
  1. Do nothing
  2. 1200 gauge DPM
  3. Dry sand
  4. Leveling compound
  5. Other?
Thanks
Hi,
We started off with what you've got.
Dpm then 2 layers of insulation - 1st at 90deg to the beams.  We used 75mm celotex - this 'crushes' slightly - joints taped.  Next 150mm celotex at 90deg to the first layer - if they rock (celotex is far from 'flat' - this surprised me) then use some sand to bed them onto.  Take your time and you will achieve a level floor that doesnt rock.  The screed will take out any imperfections.  We put another sheet down under the ufh pipe and don't skimp on the clips - you dont want them lifting while the screed is going down (screeders said this wasnt unheard of).  Remember to grout the B&B (ours wasnt done very well so I redid it).  Dont be tempted to turn the celotex upside down - the underside foil isnt bonded on very well.
Hope that helps.
