Simba_ali Posted November 21, 2020 Posted November 21, 2020 Hello, I've decided to try and patch point a small area of a wall. I need some advice of the best way of colour matching mortar. I've attached a photo of the type of colour which is a coarse sandy grey colour. Someone recommend 4 parts yellow sand, 1 part sharp sand and 1 part master Crete cement, does this seem about right?
tonyshouse Posted November 21, 2020 Posted November 21, 2020 Mix sand and cement using teaspoon dry, there are a few choices of local sand and darker or lighter cements, 4, 5 or 6 and 1then 4.5, 5.5 etc. Once it looks good dry mix wet. Put in airing cupboard shaped, and rubbed to dry, check match the next day
Simba_ali Posted November 21, 2020 Author Posted November 21, 2020 (edited) Sorry do you mean 4,5,6 and 1 as in sand to cement ratio? Judging by the photos should I start testing with a darker sand? Or normal yellow? Edited November 21, 2020 by Simba_ali
Russell griffiths Posted November 21, 2020 Posted November 21, 2020 There’s no sharp sand in that mix of yours. You can try fine sharp 2mm or less or Leighton buzzard. Have a trip around all the local merchants and buy half a dozen bags and just have a play.
tonyshouse Posted November 21, 2020 Posted November 21, 2020 Mix looks like with grey sand mix ratios 4:1 and 5:1 and 6:1 then when close to correct colour try 5.5 etc
Simba_ali Posted November 21, 2020 Author Posted November 21, 2020 So you guys reckon it's a grey sand rather than a yellow? How can you tell it doesn't have sharp sand? Not doubting you, just curious!
tonyshouse Posted November 21, 2020 Posted November 21, 2020 Yes but coloured, it seems quite glassy to me, most likely to be local and probably as dug.
