Kernow Posted October 19, 2020 Posted October 19, 2020 We are building a 2 storey property out of ICF (nudura), that has a number of steel lintels/posts. The question is when does this steel require galvanizing? My understanding is that traditionally anything exposed to the cavity will require galvanising, but where does this leave steel used in the line of the concrete core, or as a post to support a corner? Thanks
Conor Posted October 19, 2020 Posted October 19, 2020 Note on our engineers drawings: "3. WHERE STEELWORK IS EXTERNAL OR WITHIN ICF WALL IT SHOULD BE EITHER GALVANISED OR DOUBLE COATED WITH BITUMINOUS PAINT"
Mr Punter Posted October 19, 2020 Posted October 19, 2020 If it is encased in concrete it will resist corrosion. Just a post in the external walls should be galv or stainless.
Kernow Posted October 19, 2020 Author Posted October 19, 2020 1 hour ago, Conor said: Note on our engineers drawings: "3. WHERE STEELWORK IS EXTERNAL OR WITHIN ICF WALL IT SHOULD BE EITHER GALVANISED OR DOUBLE COATED WITH BITUMINOUS PAINT" Thanks, a couple coats of paint is sure to be cheaper than getting everything galvanised. 29 minutes ago, Mr Punter said: If it is encased in concrete it will resist corrosion. Just a post in the external walls should be galv or stainless. The lintels won’t be totally encased in concrete, but sitting on top of the concrete core to take the roof trusses.
