Pocster Posted October 8, 2020 Posted October 8, 2020 Had a quick look at this . The drain has no grate - is that correct ? Also the cover seems a bit crap - it can slide around and just sits on some rubber legs ( one is broke ) . Is that it ? . Going to clunk and move when you step on it . Am I missing something ???
Carrerahill Posted October 8, 2020 Posted October 8, 2020 (edited) On 08/10/2020 at 09:23, pocster said: Had a quick look at this . The drain has no grate - is that correct ? Also the cover seems a bit crap - it can slide around and just sits on some rubber legs ( one is broke ) . Is that it ? . Going to clunk and move when you step on it . Am I missing something ??? Expand It looks like it! A bit of an afterthought in the design department I think! My only comment would be, apart from yes it's a bit poor, given it's proximity to the glazing, are you likely to stand on it in use? Once you have got it all installed and working for a while, I'd be tempted to silicone it down with a couple of blobs. Just enough to lock it in place and that you can pry it back up. Edited October 8, 2020 by Carrerahill 1
Pocster Posted October 8, 2020 Author Posted October 8, 2020 On 08/10/2020 at 09:33, Carrerahill said: It looks like it! A bit of an afterthought in the design department I think! My only comment would be, apart from yes it's a bit poor, given it's proximity to the glazing, are you likely to stand on it in use? Once you have got it all installed and working for a while, I'd be tempted to silicone it down with a couple of blobs. Just enough to lock it in place and that you can pry it back up. Expand Yeah I was thinking a bit of silicone . Is rather crap especially for an expensive tray . The instructions say the drain must be at the other end from the shower . So you effectively have to walk on it ?
