As @ProDave said - you can’t get to anywhere close the levels of thermal insulation and probably air tightness needed to get to not needing any heat on upper floors. I am with your builder who is suggesting radiators - by all means if you’re putting in new ground floors then UFH (at 100mm centres) would work but a higher temperature system with rads would be required
