Vijay Posted September 6, 2020 Share Posted September 6, 2020 Afternoon, I'm ok with giving up on the idea of a thermal break in my garage door thresholds, but would still like to exhaust the options and feasibility. Seeing Russell's post earlier mentioning XPS 500 https://www.soprema.co.uk/en/product/insulation/xps/xps-500 I wondered about that product as it states "XPS 500 is mainly used as thermal insulation for floors and car parks where a high compressive strength is required." Now what I'd really like to know if anyone can help, is what sort of compression figure I would need for cars to drive over. I know I would still need something to make/cover the actual threshold that the tyres would physically drive over, but I'd imagine that can be thinner if the compression of the product under it is higher?? Cheers Vijay Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 6, 2020 Share Posted September 6, 2020 That board is 80mm thick, if you stood it on its side and had a 10mm x 80mm wide strip of fibreglass on top glued on I don’t think you will ever need to work out the load, the car will glide over it without hardly touching it. Link to comment Share on other sites More sharing options...
Vijay Posted September 6, 2020 Author Share Posted September 6, 2020 so they are 100x80 and not a sheet material? I have also looked into Foamglas and they have mentioned using cement board on the top which is something you just posted about using under your doors Link to comment Share on other sites More sharing options...
Russell griffiths Posted September 6, 2020 Share Posted September 6, 2020 No they are a funny sized sheet, probably something like 1200x 600 x80 with a half lap type joint on the edges. I just pushed them through the table saw. Link to comment Share on other sites More sharing options...
