SteveMack Posted July 29, 2020 Posted July 29, 2020 My new SE Has said for our extension if we get a GI done so we have the soil bearing capacity we can potentially reduce our foundation spec. Existing house is built on sand/soil from what I know of local area and from a 6m deep hole United Utilities recently dug about 100m away from our house (Granted a lot can change in 100m I agree) I've been quoted £1400 for 2 micro bore holes and report, is it even worth it at this cost or is there a cheaper way to proove what we need/should I be paying less? I've already dug down to our existing foundations to check existing size
Temp Posted July 29, 2020 Posted July 29, 2020 (edited) As the SE what he expects. Our ground condition report involved digging two holes with a digger rather than "micro bole holes". Perhaps even ask him to recommend a company and what he thinks it should cost in your area. You might also get a percolation test done at same time if you will need soakaways or similar. Edited July 29, 2020 by Temp 1
Russell griffiths Posted July 29, 2020 Posted July 29, 2020 Has there been any extensions done locally to you ? Go and ask what they did. Have a drive around and chat to a local builder doing similar, get a feel for what is generally done around your way. I spoke with 3 local developments and knew I was going to have to pile mine without getting a survey. 1
SteveMack Posted August 3, 2020 Author Posted August 3, 2020 (edited) On 29/07/2020 at 22:09, Russell griffiths said: Has there been any extensions done locally to you ? Go and ask what they did. Have a drive around and chat to a local builder doing similar, get a feel for what is generally done around your way. I spoke with 3 local developments and knew I was going to have to pile mine without getting a survey. Our estate is quite small off a main road consisting of 24 houses, 1 has an extension but the people who extended it moved house 3 years ago before we lived here Behind us is nothing but farmers fields for miles too; so I'm very limited with this method Edited August 3, 2020 by SteveMack
