so we have an external cabinet, earth rod powering a small consumer unit, for temp power.  when I get sparky round to fit consumer unit, 1st fix etc do I also have to get western power out again to connect the proper earth so the earth rod can go, or does the sparky do that?
Is the supply staying in the same place, i.e. in the outside box, or is it moving into the house.
If it is staying, the PME earth is usually available without bothering the DNO.  Can you post a picture of your supply head and incoming fuse?
