We're using Thermabeam rather than beam and block, but the compressive load under the supports will be similar. As there are concentrated loads, do I need to use a specific type of DPC? What DPC do people use for beam & block beams to bear directly on?
I used high loaf 600 mil So I could fold it out to rap the edge of the beam and sit my first course of block on
Thanks @nod
High load: Do you remember the brand you used? I've seen this commonly available, but no idea if any good:
    https://www.ikogroup.co.uk/product/iko-hyload-original-dpc/
600 mil: I read that as you used a 600mm wide DPC folded up over the beams, sounds like a nice approach.
Edited by MortarThePoint
If you just ask for high load Dpc
The BM will know what you mean
One of The handiest Things is with it being thicker it’s easier to keep in place
