Rob Johnson Posted June 18, 2020 Posted June 18, 2020 Is it easy enough to service the Genvex Premium? I can replace the filters and can balance the system but thinking about oiling the fans ? Any one tried this? And is it just me or does everyone else turn the MVHR off during the summer?
MikeSharp01 Posted June 19, 2020 Posted June 19, 2020 Hi Rob. Two members I am aware of, there are probably others, have Genvex MVHR systems - @Jeremy Harris and @PeterStarck hopefully they will be able to help. I also wonder why you would need to oil a fan, most such systems have life sealed bearings. Most MVHR system have summer bypass modes so you still get the ventilation but don't recover the heat. If you are happy to have open windows then you may get away with turning it off but also if you have an ultra airtight home you may degrade the air quality without the MVHR running and the windows closed.
Gone West Posted June 19, 2020 Posted June 19, 2020 We have a Genvex Combi 185LS and we leave it running continuously all year. As Mike said the the fan motors have sealed bearings and there isn't anything to oil. On mine the only servicing needed on the MVHR side is changing the filters and checking whether the heat exchanger needs a clean. I also vacuum out the filter housing if needed.
Rob Johnson Posted June 19, 2020 Author Posted June 19, 2020 Thank you gents. I bought a carbon dioxide monitor to check air quality. My logic is that if I can keep the air quality good /ish (below 1000 ppm), why use the unit? My dear wife still likes to hear the birds in summer ... she would also like to have the bedroom windows open in winter!
MikeSharp01 Posted June 19, 2020 Posted June 19, 2020 MVHR is more than air quality it also recovers heat and if you have the windows open in the winter you might find that feature valuable - unless you have pots of money and don't mind the challenge extra heating give the planet.
