jfb Posted May 20, 2020 Posted May 20, 2020 I have a small internal timber frame dividing wall that I want to render on to. What is my cheapest option for a board that takes render? A quick look at the internet finds options like this: https://www.insulationshop.co/9mm_renderflex_polymer_render_carrier_board.html But they seem expensive!
nod Posted May 20, 2020 Posted May 20, 2020 Plasterboard it then attach galvenised mesh Then two coat render Or mesh directly onto the stud Two scratch coats One top coat Three seperate days 1
Mr Punter Posted May 20, 2020 Posted May 20, 2020 Or this nailed to the studs https://www.insulationshop.co/600x2500mm_galvanised_steel_rib_lath_sheet.html 1
jfb Posted May 20, 2020 Author Posted May 20, 2020 excellent suggestions. I have some expamet lying around so I will go with that. Not sure why I didn't think of it given the number of bits of timber in the old walls I have covered with expamet before rendering already!
