wozza Posted May 14, 2020 Posted May 14, 2020 Hi All, I understand what MR (Moisture Resistant) Plasterboard is and its properties, however I am questioning if it is worth using if you are going to skim coat over it? Its a bit late now reqardless as I have boarded out most of the two bathrooms except for one ceiling and two dot and dab walls (with a combination of Abacus boards for the wet areas and MR plasterboard everywhere else) Also I have seen the Mould resistant Fiba tape - is it worth using? Thanks, Wozza.
nod Posted May 14, 2020 Posted May 14, 2020 Yes you should use moister resistant boards in all bathrooms regardless of weather they are being tiled or painted 1
nod Posted May 14, 2020 Posted May 14, 2020 Just now, nod said: Yes you should use moister resistant boards in all bathrooms regardless of weather they are being tiled or painted Ps ceilings also 1
bassanclan Posted May 14, 2020 Posted May 14, 2020 But ideally you wouldn't skim tge parts that are getting tiled 1
