LA3222 Posted May 6, 2020 Posted May 6, 2020 I'm currently putting some 47x50 timber battens around the window openings to close the cavity around them. I've offset them by 10mm so I can stick some aerogel insulation there which I have left over to help with thermal bridging. My query is should I cover the face of the battens with some DPC in order to mitigate water potentially coming through the blockwork? I seem to recall reading this somewhere which is why its bubbling at the back of my mind but cant find an answer anywhere so wonder if I have misremembered?
Russell griffiths Posted May 6, 2020 Posted May 6, 2020 (edited) I would, you used to when you closed the cavity with a block, but now most of it has changed to plastic cavity closers i think any chance of moisture bridging should be avoided. Edited May 6, 2020 by Russell griffiths 1
