sw879 Posted April 28, 2020 Posted April 28, 2020 We need a fire rated door for our kitchen and had planned on having a crittall style bi-fold door . However, after hours of searching and making enquiries to various companies (e.g. tod’s doors) this doesn’t seem possible. Is it correct that bi-fold doors can’t be fire rated? Any help/guidance would be appreciated. Thank you
Roundtuit Posted April 28, 2020 Posted April 28, 2020 Hi. Just for clarity, this door is between the kitchen and what?
nod Posted April 29, 2020 Posted April 29, 2020 7 hours ago, sw879 said: We need a fire rated door for our kitchen and had planned on having a crittall style bi-fold door . However, after hours of searching and making enquiries to various companies (e.g. tod’s doors) this doesn’t seem possible. Is it correct that bi-fold doors can’t be fire rated? Any help/guidance would be appreciated. Thank you I’ve recently finished a self build for a family and the lady of the house is heart broken for this reason The Ground floor is 245m2 she was wrongly advised by her architect that she could split the dining area from the rest of the house with large bifolds The dining area is open to the kitchen This relates to the house being three story BC have stated that to have the bifolds She must install fire doors between the kitchen and diner I guessing yours is more than two story
sw879 Posted April 29, 2020 Author Posted April 29, 2020 9 hours ago, Roundtuit said: Hi. Just for clarity, this door is between the kitchen and what? 2 hours ago, nod said: I’ve recently finished a self build for a family and the lady of the house is heart broken for this reason The Ground floor is 245m2 she was wrongly advised by her architect that she could split the dining area from the rest of the house with large bifolds The dining area is open to the kitchen This relates to the house being three story BC have stated that to have the bifolds She must install fire doors between the kitchen and diner I guessing yours is more than two story Thank you for your replies. Our kitchen leads out into the hallway and I’ve attached a plan for you to see (sorry I couldn’t find one with measurements). We didn’t want our kitchen door to be visible at first and had initially planned on a pocket door but because of an upstairs neighbour’s pipe work that runs through our home we couldn’t incorporate one. We decided on a bi fold door instead and had intended on keeping it folded away to the left behind the stud wall but we are struggling to find one.
nod Posted April 29, 2020 Posted April 29, 2020 Are you three story If you are over two You don’t need a fire door from your kitchen to living areas
sw879 Posted April 29, 2020 Author Posted April 29, 2020 1 hour ago, nod said: Are you three story If you are over two You don’t need a fire door from your kitchen to living areas We are a two storey. The kitchen is upstairs with a guest toilet and living dining room. Downstairs are the two bedrooms two bathrooms. Do you mind sharing where it says we don’t need a fire door? I believe you but I just want to have some evidence to show the building inspector/our builders. thank you so much!
Jeremy Harris Posted April 29, 2020 Posted April 29, 2020 2 hours ago, sw879 said: We didn’t want our kitchen door to be visible at first and had initially planned on a pocket door but because of an upstairs neighbour’s pipe work that runs through our home we couldn’t incorporate one. 4 minutes ago, sw879 said: We are a two storey. The kitchen is upstairs with a guest toilet and living dining room. Downstairs are the two bedrooms two bathrooms. Do you mind sharing where it says we don’t need a fire door? I believe you but I just want to have some evidence to show the building inspector/our builders. The fire door requirement may well be because of "your upstairs neighbour", if I've read these posts correctly. The requirement will be driven by the nature of the building, rather than that of one dwelling within it, so a bit more detail about that may help decide whether what you're being told is correct.
sw879 Posted April 29, 2020 Author Posted April 29, 2020 Ah thank you Jeremy! That completely slipped my mind.
sw879 Posted April 30, 2020 Author Posted April 30, 2020 We don’t need a fire rated door for our kitchen if we have smoke alarms in the downstairs bedrooms and corridor. Problem solved! Thank you everyone for your help.
