Bored Shopper Posted April 26, 2020 Posted April 26, 2020 Need advice please: FF bathroom is due to have a square(-ish) bathtub (1050x1250mm, 600mm deep). Total water capacity 428l. Users will be above 110kg. Now the floor structure is timber joists N. G2,47*250mm Grade C24@0.40mCTRS (taken from SE plans). We've made that double joists, bolted together. The new builder (we've had a change of builders this months, don't ask...) says it would probably need a metal plate support on top of joists to ensure the full bathtub does not cause joists movement. Architect says maybe not. Any opinion please?
nod Posted April 26, 2020 Posted April 26, 2020 I used I joists under our 60 KG tub I doubled a couple up under the tub Mainly because I hadn’t used them before Boarded them with 22 mil Caba board and 15 mil Porcelain on top Then the tub I spoke to the floor design company at the time and they said while I could double up there was no need
