Contractor has fitted single ply flat roof, all seems good
They have left me a 56mm outside diameter Sarnafil T Drain outlet to connect on to. A quick email to Sika Sarnafil and they suggested using a jubilee clip, ? really??  Contractor says a standard pvc pipe will work, but 56mm seems an odd size, too big for 50mm and too small for 63mm.
The connection will be inside a ceiling cavity so needs to be 100%.
Any ideas?
Yes a 50mm would fit inside but that seems like it's asking for trouble.
I need an elbow fitting that I can solvent weld preferably.
Failing that a larger diameter pipe that could go up and over the outlet and then hope it never backs up.
