9kWp 3ph Solar live
Benjseb
Finally installed and gone live
We installed a 63amp submain to new holiday let
that has 9kWp solar array with inverter
then in the holiday let and the main house we have solar inverters which feed an immersion in both our DHW tanks
theres also a secondary “overflow” output which will heat up our underfloor buffer tank
Only went on at 12pm731FA0EA-0070-4764-B7BF-A33A78B43D6C.thumb.jpeg.641ce782a5557c9e31d6a1f01660bcd7.jpeg and generated 30kWh today so happy with that.
Edited by Benjseb
The Apollo GEM is a good bit of kit. Simple to install and set up.
I had one working on my dual Sunamps and worked well until the problems with cold start on the controllers was revealed. Since then it’s been sat in a box :(
