Quick Question - Switch Power Supply
Delicatedave
6 minutes ago, Jeremy Harris said:
Yes, it has to be earthed as it has exposed metal parts.
Yes, as I said silly question but I've seen so many with use twin lighting cable. Just I have one handy but I shell resist the temptation and use an old PC power cable and plug it in.
There will be some type of filtering on the input which inevitably means some leakage.  With no earth, the case would probably adopt a voltage somewhere between L and N and would give you a shock if you touched it,
Strikes even me as a simple way of turning 'delicate' into frazzelledDave
