March 21, 20206 yr Could a CLC/Foamed concrete of the appropriate mix be used instead of a traditional concrete mix in an ICF build? Is there a particular reason if not, why? I mean it's used in roads structure infill and such..
March 21, 20206 yr Author Better insulating properties, lighter so one would assume cheaper to transport, no requirement for vibrating and in parallel less likelihood of creating voids. But that's not the question really. If no one has thus far done it, I wonder why.
March 22, 20206 yr Ask an SE. That's the trouble with asking interesting questions ... when you do, the first impulse is to do it the same way as before. And the next to deflect responsibility for the answer to an expert. Try it?
