oldkettle Posted November 20, 2016 Posted November 20, 2016 Hi, I have finally got an engineer to disconnect gas from the fireplace we have. Since we are planning to remove fireplace completely when we build the first floor I wanted to "enjoy it while it lasts" and burn wood on some particularly cold and damp weekends. So yesterday I removed artificial logs and proudly put on a self-lighting log. https://www.flickr.com/gp/97587014@N08/S15j61 It was all going well. https://www.flickr.com/gp/97587014@N08/919W27 And then I added a proper log. Within 5 minutes the room was not a great place to be in. It was not full of smoke but there was enough to feel uncomfortable. The flue was definitely open - I have only figured out how to close it today Even now, after keeping windows open for well over 5 hours, I still feel the smell. So I removed the damper rod and had a closer look. Judging by the name I have managed to read - New Marathon - there is an unused back boiler behind the fireplace. One of the pipes is cut, I guess intentionally, to prevent it from blowing up. https://www.flickr.com/gp/97587014@N08/i85w8V https://www.flickr.com/photos/97587014@N08/30988319822/in/album-72157675531126370/ Since my experience with fireplaces is non-existent, can somebody please tell me why did it go wrong so spectacularly after I added wood? OK, the first log is "no-smell, no smoke" but still it was not like all smoke was going in. Is it still safe to keep using it with these special logs?
PeterW Posted November 20, 2016 Posted November 20, 2016 Is it definitely a coal flue or has someone restricted it or re-lined it for the gas fire - did you try a smoke match first ..?
MikeSharp01 Posted November 20, 2016 Posted November 20, 2016 Yes, can you see all the way up it? If you can then its likely you have a negative pressure problem which the heat from the log cannot overcome, sometimes happens in 'funny weather' - try a smoke test if you cannot see up it.
oldkettle Posted November 20, 2016 Author Posted November 20, 2016 (edited) I can't see all the way up - it makes a turn after about 50cm+. I don't know how the lined one should look like TBH. To my eye it is simply a thick metal. It seems to get to say 25cm diameter before it turns but the turn is wide. There is a lot of soot there. I can see the flame of the lighter getting much taller as I bring it closer to the flue. Was the same when I tried to burn the paper a couple if years ago as a test. I can try part of the process from here http://www.bfcma.co.uk/smoketesting.aspx sometime, but there is no way I am going on the roof - it is not that high (bungalow) but I don't want to take any risk with the old slates. It least I should see whether the smoke gets all the way out. Edited November 20, 2016 by oldkettle
