oranjeboom Posted February 26, 2020 Posted February 26, 2020 Plasterboard butts up against a ceiling beam and having siliconed the junction I now see it's pulled itself away from the wood. The wood was painted first and then silicone was applied. Not sure whether it was a high modulus one, probably just a general builder's silicone. As there's a slight movement here during warmer weather, it needs a flexible sealer. Any recommendations? Plasterboard / painted wood junction: https://www.toolstation.com/premium-building-silicone-310ml/p56400 - apparently sticks to wood (but probably not painted wood).
Moonshine Posted February 26, 2020 Posted February 26, 2020 Why not just standard decorators chauk? It has flex to it, so will allow some movement.
bassanclan Posted February 26, 2020 Posted February 26, 2020 You should wait 6 months after plastering and then use decorators caulk
oranjeboom Posted March 5, 2020 Author Posted March 5, 2020 Thanks. I've used caulk before but was never impressed with it as found it to crack after a while also and was not something I had considered using again. I'll give it a go and hopefully no issues with it this time.
