My middle lounge, between the front room and the conservatory at the back, is rather dark. It is approx 4.2m x 4.2m, so small-medium size.
At present it has a central single pendant fitting.
I am casting around for a fitting with several bulbs to make the room brighter.
In search of examples, does anyone have a fitting of this type that you like?
I will consider a wiring modification with a project in a couple years, but for now I can only sensibly change the light fitting.
Cheers
Ferdinand
Edited by Ferdinand
My only advice is look at your wiring before you buy. Unscrew the cover of the pendant and see how many wires are there.
If more than 2 (one pair) then choose a light fitting where the base that fits to the ceiling is quite large. Some of the smaller ones can be really hard to terminate "loop at light" wiring.
