Hi
This my 1st building project so i need advise please.
I intend to build a sips panel single storey extension of around 20m wall length. The floor level of the house is around 500mm above ground level. The previous owners had already added a concrete base at that height so i want to  add to that (3m x 5m).
The concrete i will either have poured or do my self depending on price  is 1.8m x 7.7m x 500mm= 6.93m3, half is on grass and half is on concrete.
The new concrete will but up against the other concrete and an external brick wall.
Will i need expansion joints?
How much is the concrete?
Im sure i will have more questions but first things first.
Thanks
Have you had a building regs drawing done for this?
you will probably need to remove everything the previous owner put down unless it is insulated and has a damp proof membrane installed.
I would talk to your architect or building control.
