Beam Foundation build
colin7777
After many months working through Timber frame companies and foundation options we are very close to making a decision but just looking for some views / clarity as to the foundation / floor insulation.
We have to have piles due to being by a river that will have a steel ring beam. it is a small one and three quarter property approx 13 metres by 6 metres and looking to use block and beam.
We are not aiming for a highly insulated house, walls have an estimated 0.16 U, and ceiling has an estimated 0.13U. The timber company can supply the floor insulation and have quoted 90mm Kingspan kooltherm K103. Does this seem a sensible thickness to get a balanced U value for the property, would there be any benefit to increasing the thickness for comfort / cost benefit.  The bedrooms are on he ground floor and we have decided not to have UFH .
Their diagrams show that the timber frame would be placed on two layer of bricks which I guess takes up the insulation and screed height, I was expecting the timber frame to be fixed directly to the screed / Block and beam. One thing that puzzles me is how everything is going to be held down  if brick is used:
Timber Frame
Sole Plate
DPC
Brick
Beam and block
Steel Ring Beam
Any ideas, comments, experiences, do's and don't or any views on any aspects welcomed.
Colin
Edited by colin7777
Floor insulation is simple and cheap to install so you may want to go a bit thicker.  The screed does not need to finish level with the bricks.  You will normally have a 38mm thick sole plate plus the bottom rail of the timber frame so you could go 120mm insulation, 60mm screed and there will still be 46mm of timber at the bottom to fix your plasterboard.
The timber frame firm should design the holding down detail.  It could be metal straps fixed to the floor or screws and plugs.  Ask them.
Edited by colin7777
changed
