Big Jimbo Posted December 17, 2019 Posted December 17, 2019 Evening all. I have spent a few hours on the Labc foundation depth calculator today, and if i want to do strip founds, i range from about 2mt deep to 1.5mt . I am told by a builder who has just built 3 houses very near me that i am on good ground. He went 1mt deep, but i have trees, hence why mine need to be deeper. I know that going deeper than 1.5mt will mean that i will need heave protection to the inside of the trenches. Because i have a fair few old buildings to take down, i wanted my floor to be a ground bearing slab, ie; old building rubble 150mm min. 50mm sand, dpm, cast concrete 150mm. insulation and screed. I think i have read somewhere ? that if my founds are deeper than 1.5mt, than i cant have a ground bearing slab as my floor. Anybody have any idea if that is right ? If it's to do with heave, could i not compensate by having a layer of heave protection on top of my sand ? and if necessary putting some re-enforcing in my 150mm layer of concrete ? Still waiting for my engineer to come back to me. Thanks in advance.
Oz07 Posted December 17, 2019 Posted December 17, 2019 Not usually accepted on deeper founds. Might be best off excavating an concrete before deciding on slab/floor. Bco might only make you go 1.5 1
nod Posted December 17, 2019 Posted December 17, 2019 Ours where pretty similar to yours 1.5 to 2000 Good ground surrounded by Ash and oak trees I used clay board to help with the heave Engineer specified BB However I built two D garages Same foundations BC was ok with me using a slab foundations for these He specified 25 mil insulation around the perimeter to keep the concrete off the walls 1
