Due to the delay with planing application change I wasn't able to put the roof before winter.
I have exposed Ytong blocks up to the wall plate height.
I would like to ask if anyone has any thoughts / recommendations  in terms of protecting the walls for the winter from rain / frost to avoid any structural damage.
Thank you in advance.
On 30/11/2019 at 08:05, Russell griffiths said:
Hessian for frost, dpm for rain, few loose blocks on top, job done.
Thank you Russell for your comments.
Would you advise to cover from the top of the wall to the bottom or only the top couple rows and window openings?
On 02/12/2019 at 07:51, Russell griffiths said:
Depends how bad your weather is, down here I would just cover the top couple of courses.
Thank you for your comment. I am based in Bedfordshire
