Pocster Posted October 24, 2019 Posted October 24, 2019 (edited) I'm sure there was a thread on this before. But anyway! Any recommendations Qubino over Fibaro ? Also when these 'switch' are they noisy? ; I'm assuming it's not a mechanical switch... I'm going to have a good few of these in a DIN cabinet so if it's clicking all the time might driver me mad. (der - before anyone else suggests that edit) Taking this one for example: https://www.amazon.co.uk/Qubino-ZMNHSD1-Din-Dimmer-Grey/dp/B01DL8OWS8/ref=asc_df_B01DL8OWS8/?tag=googshopuk-21&linkCode=df0&hvadid=231965104222&hvpos=1o1&hvnetw=g&hvrand=6144952454685597230&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9045635&hvtargid=pla-422963820217&psc=1 Looking through the blurb I see the attached Does that mean it can switch multiple lights upto 200W (if 240V lights)?. If so how are the lights wired ? i.e. as there's just the return to the Qubino unit. Think I've found a sparky - but he's new to all this HA stuff...... Edited October 24, 2019 by pocster
MrMagic Posted October 25, 2019 Posted October 25, 2019 Looks like the cost of these has dropped since I first looked at them. Not used Qubino before but I'd be tempted if I was doing it again. In the end I used normal Fibaro dimmers + a 3D printed DIN rail holder which actually now costs the same as the DIN Qubino! Just had a quick flick through the manuals - the only thing I could see is that it looks like the Fibaro can be switched to leading edge dimming rather than trailing edge which *may* make it more compatible however dimmable LEDs have moved on leaps and bounds so I don't expect you'll have any issues. The only change I had to make was to raise the lower dimming limit as when it was down <10% I got flicker from my LEDs 1
